Create solid between 2 surfaces
kubastan89
Message 1 of 12
kubastan89
I have 2 surfaces (attached to the post) and I want to create a solid between these 2 surfaces.
I was trying to extract solid from surface at a surface and trying to use Dynamo to extract solid but none of these was able to extract solid.
Does anyone have any idea what else I could try to extract solid ?
Replies (11)
Message 2 of 12
ianjchap
Hi @kubastan89,
If the two surfaces are equal distance apart across the whole area (which yours seem to be), the easiest way would be to extract solids from surface, entering the depth as the same distance between the two surfaces.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 12
kubastan89
Hi, I already mentioned that I got an error after trying this method.
Message 4 of 12
ianjchap
What happens when you ry to extract Solids from surface? ie. any error message etc.?
Ian Chapman
Message 5 of 12
kubastan89
Message 6 of 12
nkiakas
Hi @kubastan89
Are the attached ok?
I found out that your surfaces are exactly the same, with elevation difference 0.62.
If have LOT of surfaces to export solids, then you need Dynamo. If not then you can do it one by one...
Regards
Message 7 of 12
ianjchap
Hi @kubastan89.,
Extracting solids from your model worked fine for me, so potentially something up with your setup.
Try extracting Triangles or Points from the surface, copy those to a new session, create a surface and extracting Solids from that.
Ian Chapman
Message 8 of 12
kubastan89
Hi @nkiakas
I also tried to create a solid using Dynamo with attached script but also get an error.
How did you manage to create this solid ?
Could you attach solid to this post ?
Message 9 of 12
ianjchap
I used the extract Solids feature, worked fine for me as mentioned, Solids DWG attached to my last post.
Ian Chapman
Message 10 of 12
nkiakas
Hi @kubastan89
Created solid only from one from your surfaces with depth -0.62
Creation of solid between 3 surfaces did not work for me and i did not try any Dynamo script
Regards
Message 11 of 12
nkiakas
Hi @kubastan89
Attached is file created
Regards
Message 12 of 12
kubastan89
Actually I don`t know why I was trying to extract solids from surface at a surface instead of extracting solid using just depth. Depth option work fine for me and don`t get any errors.
Thank you all for help.
