Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I'm using Civil 3D 2024.3
I'm trying to create a Point Group by Include points with Numbers matching, but when I select the points the message "Type do not correspondent" (in portuguese "Tipo não correspondente") appears, and the point group is not created. Printscreen below.
This error seems to occur when the selected points are not in order and they are separated by commas (1019, 1142, 1411, 1421).
If I specify a range of point numbers by separating the beginning and ending numbers with a hyphen (for example, 1411-1418) the point group is creted normally.
I've tried to create the exactly same point group (1019, 1142, 1411, 1421) in Civil 3D version 2024 and it worked normally.
This error could be a issue from the Civil 3D 2024.3?
Please, help me.
Thank you.
I believe this is an error in the 2024.3 update.
Rick Jackson
Survey CAD Technician VI
Hi Juliana,
Thank you for submitting your question in our discussion forums.
I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
I'm sorry to hear that you're experiencing issues with Civil 3D. I see that you've already submitted a case to our support team, which is a great step forward.
If you need any further assistance or have additional questions while you await a response from our support team, please don't hesitate to reach out here. Our community is here to help in any way we can.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Hi!
I´m also having the same issue.
I noticed that only the first point (2146) and the first set of points are getting selected (2148-2151). Point 2147 is also included, but shouldn´t be on the list and the second set of points (2185-2199) doesn´t get included with the selection
I´m using Civil 3D 2024.3 Update.
This is also happening on Civil 3D 2025.
Thank you!
Hi Alex,
Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Hi Juliana,
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! As Dave mentioned, could you try uploading your drawing file (without any sensitive information)? This would allow others to test the behavior and offer more specific advice.
