Civil 3D Forum
Create manual points by angles and distances with backsight 2015
3 REPLIES 3
462 Views, 3 Replies
In civil 2010 to create a set of points using a starting point with a backsight on a line of reference, I use the commands: create points manually, 'ss, p, click starting point, then backsight, then enter the angle and distance. And the angles always reference the starting point with backsight not the last drawn point. Now when I tried this on my computer civil version 2015 I clicked create points manually, 'ss, then it asked for either p,n,g. p being point, n being northing, and g being pick object . None of these were the option to pick a starting point with a backsight (p). How do I do what I was doing in version 2010 easily and efficiently in 2015?
Tags (3)
3 REPLIES 3
Pointdump
Pointdump
A,
I don't have 2015 to test this, nor 2010 to see how it was, but 2016 works OK. All I can suggest is to install latest service packs and try again.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
A,
Dave
Dave Stoll
Las Vegas, Nevada
in reply to: Pointdump
Thank you so much! it works great now. It was the security hotfix update that it needed. THANK YOU!!!
rl_jackson
rl_jackson
I'm with PD on this one using C3D15_SP3
Did these steps.
  1. Draw line.
  2. Pick Create Manual
  3. Select 'ss Transparent Command from Toolbar
  4. Select Line at nearest instrument position
  5. Angle - Distance request
  6. Enter Description
  7. A-D request etc......
Rick Jackson
Survey CAD Technician VI
Did these steps.
  1. Draw line.
Rick Jackson
Rail Community
