Dear sir /Madam
Ih problems when subassembly composer create distance to point .
Thanks you
Best regards
Solved by tcorey. Go to Solution.
Can you give more details? Post your .pkt file?
You can't attach PKT file but you have to change extension of PKT to ZIP. Or just to zip file and than you will be able to attact to forum.
I have your pkt file. Can you post a screenshot where in the flowchart you are having the problem?
You have the Cut and Fill backwards in that first decision. You are using AP2.y>P11.y as your condition, but then saying False = Cut. AP2 is being placed on the surface, so that being higher than the test point, P11, would mean Cut should be assigned to True and Fill to False.
