Civil 3D Forum
CREATE CROSS SECTIONS FROM EXISTING .DWG
7 REPLIES 7
Message 1 of 8
1456 Views, 7 Replies
Hello to everybody! I am a newby in civil3d 2012. I'm trying to find out how to create cross sections from existing ones that i have in autocad file. I allready have read for the way with offsets points, but is there a way to make full cross sections from the allready drawned????Is it possible to convert the existing lines???
7 REPLIES 7
Message 2 of 8
wfberry
You will need surface(s) to do that.
Obviously you can manipulate your existing cross sections by normal Autocad lines, etc., then plot but that is it.
Bill
Message 3 of 8
Yes, i can manipulate just in simple autocad..but i need to put the existing cross sections in order to use them for volume purposes...and since civil is such a fine program i was thinking that there should be a way to manipulate the "ready" thing Smiley Wink...there are other simplest progs where you can import existing cross sections from dxf file...thank you Bill anyway
Message 4 of 8
neilyj666
check ou wes newmans blog for the xsect 2 surf tool
http://autodesk.typepad.com/transportation/2012/10/x-section-to-surface.html
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 8
in reply to: neilyj666
Dear neilyj thank you very very much!!! this is what i am talking about!!! I am so excited and reliefed!!! you are great...I am going to try this out and inform you about the results...
and as my greek ancient ancenstors said "Aeì ho theòs ho mégas geōmetreî tò sýmpan" which means "Always the great God applies geometry to everything"
thanks again my friend
Message 6 of 8
neilyj666
hope it works for you - I've used it on several occasions with great success
Message 7 of 8
wfberry
Hey there neilyj:
After watching the video, it appears to me that I could use the PGL from the cross-sections and design it easier than digitizing all those sections.
Bill
Message 8 of 8
neilyj666
in reply to: wfberry
The choice is entirely down to the user - use whichever is quickest/easiest...:)
Rail Community
