Create Connected Alignment "Curve Reverse Curve Curve"
nkiakas
Advisor Advisor
nkiakas
Good afternoon
I am trying to model a R/A in a semi-automatic way.
Semi-automatic means, I am not going to use the R/A wizard creator, but I am going to use the Connected Alignment Command.
If you the attached, I want to create a connected alignment from Alignments 1 & 2.
The method I want to create connected alignment, according to my design, should be, Curve-->Reverse Curve-->Curve
The available methods of connected alignment do not include the above...
Does anyone have any idea to suggest any trick?
Thank you
rl_jackson
Based on the screenshot, you'd be best using the wizard, it's going to provide most if not all of that, just by specifying certain variables. Even if it didn't provide everything you needed it could get close with a little tweaking here and there.
Rick Jackson
Survey CAD Technician VI
