Message 1 of 8
Hi all,
I'm trying to create a simple alignment from a polyline with minimum curves radius of 100m - it's an access road for transportation of Wind Turbine Vestas V162, so the smoother curve is the better (see dwg attached).
The problem is Civil3D doesn't respect at all my minimum Radius of 100m - I get everything from 15 to 54, etc.
I try to modify and use a Design Criteria Fille (see Design File attached) with only one speed and radius (25 km/h and 100m) - doesn't work either.
Thanks you all for your help. very appreciated
