Create a best fit proposed surface from an existing surface and how to edit
I am fairly new to Civil 3D and am trying to replicate what i would normally do in PDS with roads but for an entire surface.
I have a proposed surface. In PDS you can take sections and then generate a line of best fit (ie minimise earthworks) and then manipulate from there. Is this possible in Civil 3D?
I have a site layout so once i have a 'best fit surface' how would i then manipulate this?
I think i can use feature lines around building footprints to create finished floor levels etc.
Once all this is done can i compare existing surface and proposed surface to calculate earthworks?
Daniel
CADobi-wan
There is no best fit option but you can create existing surface profiles from your alignments then create a design surface profile and manipulate it to how you want it to minimize cut/fill.
Hope this helps!
Please "like" and "accept as solution" if this resolves your problem!
Rob (Autodesk AEC Collection 2018, 2019)
Civil Engineering Design Specialist/CAD Manager
www.CADmitment.com
Jeew-m
Hi Daniel.Martin,
This is what CADobi-wan has suggested.
https://www.youtube.com/watch?v=-VE957b29C4
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
