Civil 3D Forum
Crash when using Layout Wizard
2 REPLIES 2
295 Views, 2 Replies
I'm working on a site plan and I need to set up a layout, but everytime I use the command "LayoutWizard", it keeps giving me this error and then says AutoCad as stopped working, exit. I am able to get to the set up screen, where I name the layout, but once I click next, it just says autocad has stopped working.
I have already tried:
1. Shutting down/restarting
2. Downloading Autocad 2015 Support files 1 & 2.
3. Uninstalling, Reinstalling
4. Software repair
It continues to stop working.
I have a Lenovo Y500, so it's a top notch laptop. I don't think my problem is a new driver. It's only a year old laptop.
Has this happen to anyone? Anything helps! Thanks in advance.
2 REPLIES 2
I found your post as I searched for a fix for the exact same thing.
I have been using AutoCad LT 2009 for 6+ years without any problems with LAYOUTWIZARD.  I D/L'd DWG TrueView 2016 and then LAYOUTWIZARD started crashing. I've done everything from clean uninstall/reinstall; install hot fixes etc to no avail. I even installed AutoCad LT 2016 and it does the exact same thing:
With dxf file open in model space:
>INSERT>LAYOUT>LAYOUTWIZARD
I get the window to designate a layout name (default Layout2).
When I select PRINTER, it crashes. Every time without exception.
Does anyone have a fix?
I have the same problem. It happend at the 2016 CAD, then I reinstalled and it happend again. So I installed the 2017 CAD and the crash happend too. It crashes when I click "finish".
Rail Community
