Cover Clerance
Cover Clerance
Message 1 of 9
Cover Clerance
Dear Experts,
I am not expert in Civil3D, I made a storm water pipe line,  I would like to add Pipe Cover Clearance and Depth of IL.   Cover Clearance Formula I know, but I don't know how to apply in Civil3D.
Formula= (Cover Level - Invert Level) then minus  (Pipe Dia & Pipe Half Wall Thickness).
Pipe Dia - 1200
Pipe Outer Dia, is  1390
Pipe Half thickness is .145
Also how its possible to add each 10M interval levels of all bands.  I attached the file for your kind consideration.
Jijina.J.
Replies (8)
Message 2 of 9
rl_jackson
Look at the Pipe rules. Then apple the rules to the pipe.
Rick Jackson
Survey CAD Technician VI
Message 3 of 9
I did not give any pipe rules,  Actually what I would like to make (Attached),  this file I made in CAD.  can you post reply with screen shot.
Cheers
Message 4 of 9
Neil.Aryan
@Anonymous,
Hopefully this will help you to show the required information's on profile view.
https://neilengineering.wixsite.com/neil/post/cover-clarence
Well cant add/show the information for pipes because pipe line information shown based on up stream end and down stream end. so i have used the profile by layout option to show the same. you can use the same method to show any other information related to pipes. feel free to discuss if you didn't get how to do it.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
Message 5 of 9
Hi sir,
Please check the cover clearance.  its getting 1.869.
Y/F
Jijina.J
Message 6 of 9
Neilw_05
I don't know of a way to enforce pipe separation requirements. I believe NAVISWORKS can help you find where there are violations to the minimum requirements but I think you have to edit the pipes manually.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 7 of 9
Neil.Aryan
@Anonymous,
Well the original post requirement was to have/show clear cover at every 10mtr interval for the main pipe network.
the one you sent image that's belongs to crossing pipe where it's completely different to the main pipe line. if you want to have/increase the pipe clear cover you have to change the crossing pipe inverts and it will update on the profile.
Cheers,
Neil
Message 8 of 9
Dear Experts
I have a specific project requirement from my client he wants to see the below mentioned requirements.
1. Is it possible to give 10M Pipe Invert levels  in Band between the two Structure from pipe network.
2. I would like to add in Band Pipe Cover Clearance levels in Band (Formula added in the Drawing)
3. I would like to add Pipe Depth in Band - (MH Cover Level - Pipe Invert Level)
4. Is any way to give existing crossing pipe Top Level fixed from the FRL Below 1M. Exactly need like Green Clouded.
The pipe rules are I given, Slope 0, Minimum Cover 1M. Maximum Cover 10M. unfortunate not getting the exact.
In the profile clouded area is some line showing related the Middle of MH. When I try to remove the Middle MH is deleting.
Does Autodesk or anyone else have a trick to show above mentioned issue,   I am new to this.
Yours early response will be highly appreciated.
Y/f
Jijina.J
Message 9 of 9
AntoninVojtesekV
Some tips:
Ad 1) You can create pipe invert profile and use it to display values every 10 m. To create this profile manually is a very tedious job so I would suggest to use third party application for that.
Ad 2) The same like above, you just need to create profile for pipe outside top. And you can use profile band which displays Profile1 minus Profile2 values.
Ad 3) The same like Ad 2)
Ad 4) I do not know any command which can do it. I know command which can move selected pipes 1 m below ground but it only sets the depth at the pipe start/end, not at the crossing alignment.
Do these crossing pipes have slope? If yes, do all have the same slope? I am asking because it might be possible to do it programmatically for all of them at once.
Technical Services Manager
Devotech Group of Companies
Devotech iDAS (Infrastructure Design Automation Suite)
