- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am looking to take a selection of block references, that each contain a numerical attribute value, and sum the attribute values in the most streamlined way possible. I have attached a file to give an example of what I am trying to achieve.
I had previously posted regarding this same task I hope to streamline, my previous post however, found here, was requesting a Lisp routine to handle this.
Since that previous post, I have discovered the 'Count' tool and am confident there is a way to write a custom expression that will read each block's attribute value, add the attributes, and produce a total value for the counted blocks. this expression could then be added as a field to the count table.
Can someone who knows coding better than I lend a hand in this?
Experienced Civil Site Designer/Drafter
Windows 11, 64 GB RAM
13th Gen Intel(R) Core(TM) i7-13850HX
