Could Not Find Alignment - help
cadman33619
cadman33619
After successfully creating existing and proposed surfaces and a volume surface with the help of Allan and bforr (much thanks),
i need to create a profile view but im getting the error :Could Not Find Alignment
if i use the quick profile i get a perfect profile of exactly what i need but i need one that is permanent. I've created a line at the correct elevation to represent my base flood elevation. i need the profile to show existing and proposed grades as well as the line representing the base flood.
Was i supposed to create an alignment somewhere?
file attached.
tmachado
Hi @cadman33619, to have permanent profiles in C3D you must have an alignment.
So I exploded your featureline and used the same line to create an alignment from objects _AeccCreateAlignmentEntities
Here is a short video that shows how to create the profile:
https://www.screencast.com/t/gND4exCe
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
cadman33619
that gave me exactly what i needed.... worked like a charm.
thank you so much.
tmachado
Is my pleasure to help!
Tatiana Machado
