Civil 3D Forum
corruption of the surface when I delete a featureline
16 REPLIES 16
Message 1 of 17
dan
830 Views, 16 Replies
I am doing a grading design using feature lines.  After many hours of successfully working on this design, all of a sudden when I delete a feature line, my dtm (surface) is corrupted.  It seems as though the some of the points along other feature lines have been randomly changed.  If I go through and change the elevations of these other (corrupted) feature lines - they wil stay as corrected until I again delete a featureline.
Does anyone have an idea of what is wrong.
16 REPLIES 16
Message 2 of 17
ToddRogers-WPM
in reply to: dan
Sounds like you do not have your feature lines organized on sites.  If your feature lines are all on the same site, then they will all interact with each other.
Also, are you using 2016 SP2?  If you are, I just logged a case with Autodesk this morning on feature line instability with SP2.
Todd Rogers
Message 3 of 17
dan
in reply to: ToddRogers-WPM
I am not sure about SP2, I have a quarterly subscription and it
automatically updates periodically. I just noticed this last week. It
seems to be that the "inferred points" on a feature line are only the ones
corrupted. It is a huge problem for me.
Dan S. Biggs PE QSD CFM
*EARTH WIND WATER* *Civil Engineering*
11440 West Bernardo Court, Suite 300
Rancho Bernardo, CA 92127
Office: 858-753-1947
Message 4 of 17
ToddRogers-WPM
in reply to: dan
That sounds about right.  I logged the case with Autodesk on this about an hour ago.  It seems to be exclusive to SP2.  I would uninstall SP2 for now.
Todd Rogers
Message 5 of 17
Pointdump
Todd,
How do you uninstall a Service Pack?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 6 of 17
ToddRogers-WPM
in reply to: Pointdump
Go to your Control Panel.   Add/Remove Programs or Uninstall a Program.  On the left hand side click on View Installed Updates.  They can be uninstalled from there...
Todd Rogers
Message 7 of 17
Pointdump
Thanks Todd! Every day I learn something new here.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 17
ToddRogers-WPM
Indeed.  So do I !!
Todd Rogers
Message 9 of 17
dan
I just checked and it seems that I do not have SP2 (Civil 3D 2016) installed.  I only have SP1.  However, I am definitely still having the corruption problem.  What do you suggest?
Message 10 of 17
ToddRogers-WPM
in reply to: dan
I logged a case with Autodesk.  Haven't heard anything back from them yet.
Todd Rogers
Message 11 of 17
Attention colleagues.  I just heard back from Autodesk.  See below...
Dear Todd,
Thank you for patience. My name is . This case was just escalated to me for my review and I will be assisting you with your case. I was able to confirm your findings and also confirm that it does not happen in Civil 3D 2016 without Service Pack. So I will go ahead and log this with development.
The ticket number is DE27807 and is linked to this case. Per process I will be closing this case out, but please know this is on the front side of support.  Behind the scenes this will remain active and further investigated by our development team here for future consideration in updates and product releases.  To further help compel the need for this functionality fix, please navigate to the link below to submit this feedback.  This will go to the project manager of the product and he in turn will bring this to the product review /discussion with the development team for further consideration on top of these efforts above.  This is a great tool and can help build further momentum in pushing this request through.
Feedback Link:  http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Please let me know if there is anything else I can assist.
Best regards,
Autodesk Support Team
Todd Rogers
Message 12 of 17
jmayo-EE
What kind of surface corruption? Never seen a surface corrupt.
John Mayo
Message 13 of 17
ToddRogers-WPM
in reply to: dan
It's actually a feature line corruption. If you add elevation points to a feature line, run an audit, it grays them out and in some instances they are deleted.
Todd Rogers
Message 14 of 17
jmayo-EE
Thanks for the info!
John Mayo
Message 15 of 17
dan
I am again having this problem.  It is a different project than before, but it is the same problem.  I never heard back from Autodesk...any ideas.  This is getting to be a real pain.
Dan
Message 16 of 17
Jay_B
in reply to: dan
Have you tried installing the Feature Line Hotfix?
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 17 of 17
dan
in reply to: Jay_B
I did as you suggested. However, after I attempted to use the Grading>Edit
Feature Line Geometry>Break ... the DEM was corrupted just as before. What
it does is set all of the intermediary points (the points of elevation on
the feature line that the user does not create) equal to "0". In some
cases, you cannot set them to a proper elevation even when selecting points
on both sides of them to a realistic elevation.
Please provide another solution.
Rail Community
