Hi all,
I have a few questions regarding 3D corridors, their labelling, and their related longitudinal profile views.
I am currently using corridors to design dry utility networks with dedicated assemblies containing several pipes whose diameter or network designation vary. All this informations are encoded in the subassembly.
I would like to know the following:
- - Is there an automated way to annotate the corridor in the plan view and display, for a given range of stations, the number of conduits, their diameters, and the network to which they belong?
- - In a longitudinal profile, it is possible to display the intersection with another alignment. In my case, this alignment represents another pipe or group of pipes located within the same trench. Is there a way to display these pipes and their cross-sections from the intersected corridor, rather than showing only the alignment?
- Do you have a usefull tutorial to or workflows for properly setting up subassembly and assembly labelling? My goal is to generate simple, clearly labelled cross sections of the networks showing the inner and outer pipe diameters, the number of conduits, and the associated network they belong to.
Thank you in advance for your help.
