Civil 3D Forum
Corridor vertical link - wrong apperence in model view
1 REPLY 1
magnussvensson
254 Views, 1 Reply
I see the same thing in 2015,2016 and 2017 and on different computers. Does anyone know if this is a new graphic card issue or if it´s always been like this?
msv
1 REPLY 1
Thank you for using the AutoCAD Support Forums. My name is Josue and I will be helping you with your request.
To assist you properly, please specify what is the operative system that you are using. For example, Windows 7 Pro 64 bits or MacOS.
You can check also if the most recent service pack for AutoCAD Civil 3D 2016 is installed, using the "about" command. In case that is not installed, you can download it from the following link.
AutoCAD Civil 3D 2016 Downloads
Best regards.
Josue Aguilar
Technical Support Specialist
Rail Community
