Corridor Transitions vs Targets
AllenJessup
Mentor Mentor
AllenJessup
I'm old fashioned. So I've tended to use targets to control corridor widths. This time I used a couple of transitions and thought they worked well. So I'm trying to use them for the whole corridor. Being, shall I say, Cautious. I wanted to have a check on the transitions. I took the polylines drawn for the EP in the design plan, copied them to another drawing and turned them into alignments. Then I DRefed them into the Corridor drawing so I could display them in the section editor. That helped me pick up some errors I had made. However.
There are areas controlled by transitions that do not match the alignments created from the EP. Mostly a couple of inches but a couple of feet in some cases. I can understand some differences where the transitions occur in curves. Its Difficult to draw curve transitions knowing only the width as each end of the transition.
My question is: Has anyone done such a comparison and did you find it was better to hold the transitions in the Corridor rather than drafted polylines?
Allen Jessup
CAD Manager - Designer
cody.faltin
I have found the transitions to be of limited value.  While I haven't conducted the same side by side check that you describe I have found that they have some limitations.
1. If you have a subassembly that only has vertical components, it is difficult to select the subassembly to start the process of creating a transition.
2. Transitions do not bridge over region boundaries well if you need to bridge over a region boundary.  For instance when building corridor in a complex urban environment.
My personal workflow has been more to utilize feature lines, or offset alignments and profiles to generate my target geometry.
AllenJessup
Yes. But for some reason I seem to be invested in making the widenings work. I may revert to Alignments for targets. Even then, I'm going to want to find out where the discrepancies come from to verify I created the Polylines I used for the Alignments correctly.
Allen Jessup
m_kingdon
I have dabbled with the transition tool and I do find it useful for certain tasks.  Particularly for some grading tasks where I want to adjust a LinkWidthandSlope or LinkSlopeToSurface grades.  I also use it for modelling dropped kerbs. i.e I model a continuous kerb using UrbranCurbGutterGeneral and use the corridor transition tool to adjust the A and G values to transition the kerb from full height to dropped height and full height again.  A bit laborious but the results look great.
I still use Offset Alignments to control my road widths and cross slopes.  I also find the limitations @cody.faltin mentioned frustrating.  It feels like the transition tool isn’t quite finished yet.  A more complete interface, ability to transition over regions and better selection options are needed.  I also want more transition methods.  It is annoying that Offset Alignments have some transition options whilst Corridor Transition has option.  I wish they could both share so we have all the options in both tools.
As for a workflow comparison against targeting polylines.  I can’t help you with that as I never use polylines as a target.  I personally avoid using polylines.  My personal philosophy is that corridors should be self-contained objects and only interact with alignments and surfaces.  The idea of a corridor interacting with something as loose and unhinged as a polyline scares me.
Mike Kingdon
Civil 3D Zealot
fcernst
Sounds like tesselation ..and frequency …and resolution issues …that need to be assessed for desired end resolution.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
tcorey
I like targets for width adjustment. I like Transitions for changing other assembly parameters. This feature makes very quick work of fitting dropped curbs into a design, for example.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
