Corridor targeting a feature line or targeting the corridor through the feature line.
sanetdikkumbura1950
sanetdikkumbura1950
Here the BUILDING PAD and the path are created. The road is about 6" lower than the building pad. The building pad is not graded. How can the curb and the building pad be connected?
Thank you.
ianjchap
Hi, @sanetdikkumbura1950,
If your building pad is at a fixed elevation, and the distance from the kerb edge varies, then you'll have a varying gradient between the kerb edge and building. Where as the daylight Sub Assembly you're showing has a fixed gradient and probably wants to target a surface. I would use a different sub assembly here, using something that will target via a width target using a polyline/feature line at the building pad edge.
It can be tricky when tieing in a road edge to a building when the footprint isn't straight forward. I usually create a separate surface for this area using an auto feature line from the corridor kerb edge, added to a surface with the building footprint feature line, then cutting out/hiding the building pad. You can create a composite surface if you need it as one at the end.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
