Corridor Target Question
So, I'm trying to get better at corridors.  I am wondering something....
Lets say you have a simple road assembly, and you want the lane width target to follow the outer edge of pavement.
My question is; if you target a Feature Line made from that Edge of Pavement, will the road subassembly follow the vertex elevations of that feature line also, perhaps overriding whatever slope you have put on that subassembly?
Appreciate any help!
tcorey
That depends on how you setup your targeting. Notice there are separate areas for width and slope targets.
Setting a horizontal target does not turn on vertical targeting. You also have to define that, if you want to use it.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Yep, I just figured that out!!  Thank you for your answer!!
