Civil 3D Forum
Corridor target option missing in 2022.1
5 REPLIES 5
jessica.miller
339 Views, 5 Replies
Where did this option go in the new target parameter screen??  This option seems to be toggled on by default in the newest version of 2022.1.  We need it toggled off & cannot locate it.
This is a corridor using an assembly with offset targets.  The targets operated fine prior to an update.  You can see the feature lines here do not find it's target.  There are multiple targets on this side.
When I uncheck this box the corridor finds it's target just fine.
The issue is we cannot find this setting in the new parameter UI.  Please advise where this setting can be toggled.  If there is a new option for handling this, please advise.
Jessica Miller
Design Technician
CEC Corporation
4555 West Memorial Road, Oklahoma City, OK 73142
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
Labels (2)
5 REPLIES 5
cneely
in reply to: jessica.miller
When  you are in the Target dialog box select an item and it will appear in the lower left. It is greyed out in certain scenarios.
AEC Collection 2022
WIN 10 PRO
Dell 3650, Intel i9-11900k @ 3.50GHz, 64 GB
NVIDIA QUADRO RTX 4000
http://www.cobbfendley.com
That's right where I'd expect it to be.  Where is it when you have multiple polylines selected as targets?  right now you have none.
This is what we get
Jessica Miller
Design Technician
CEC Corporation
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
cneely
It's the same place when multiple targets are selected in this example.
AEC Collection 2022
WIN 10 PRO
thanks.  I'm going to check some other machines.  We may have a bad install.  We've had several folks with this same issue.  Can you send a clip of the version you're in, so I can get it to our IS team?  Maybe it's fixed in an update.
Jessica Miller
Design Technician
CEC Corporation
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
cneely
Here's version info. If you can post the dwg I'll see if the issue occurs when I open it.
AEC Collection 2022
WIN 10 PRO
Rail Community
