Announcements
Corridor structure volume vs existing ground
Hello Everyone. I have a query regarding on extracting the volume from my corridor structures vs the existing ground. I manage to get the volume of the structures without the existing ground but i can't seem to figure out on how to get the structure volumes vs the existing ground. I have attached an image for reference. Thanks in advance.
tcorey
Create a Corridor Surface from the Datum. Compare Datum to OG.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Thanks @tcorey . I have done the datum part.
What i exactly want is the volume of each structure vs OG. Is there a way to directly compare the structure shape vs OG or only by surfaces? For example the pave on the image below. Thanks.
tcorey
I think I understand what you're asking.
Make a surface at the bottom of each import material layer. Compare those surfaces to OG.
Tim Corey
Redding, CA
