Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi can someone help, Ive made a corridor surface in the corridor properties menu ive added a surfece and then would usually select the top code but the drop down menu is empty. Any ideas?
Solved by tcorey. Go to Solution.
Give us a little more help - what subassemblies did you use? Can you attach a copy of your drawing?
The model is a footway along an existing road, so the footway follows the existing carriageway channel. The proposed profile is a copy of the existing gounnd profile.
The assembly is a conditional assembly it does not include a carriageway assembly just and conditionals for found and not found and the footway and curb assembly. The found and not found conditionals are there to stop the footway at the junctions.
Hello @Anonymous,
If you want to solve this yourself, look at the Code Set Style that is assigned to your corridor. Check to see if the Links section includes Top. If not, in the lower right corner, pick the Import Codes button. This will let you go to the drawing and select your assembly. The codes used in the assembly will now be listed in the Code Set Style, allowing you to access the code when building the corridor surface.
Good morning,
I am having the same issue where I am unable to add a surface to my corridor. I am not sure how to add the top link code?
Lang
C3D 2018
