Civil 3D Forum
Corridor Modelling at median
1 ANTWORT 1
Nachricht 1 von 2
NITESH_KODAGVRBM5
98 Aufrufe, 1 Antwort
I have used marked point to target the other curb to form a median top but somehow it is not working at this location shown in image
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
jeny38mark
als Antwort auf: NITESH_KODAGVRBM5
You're trying to model the median top by using a marked point on one curb to target the other curb, but the process isn't working at the specific location shown in the images. Here are some comments and suggestions to address the issue:
Alignment Check: Ensure that the marked points on the curbs are aligned correctly. Any slight misalignment between the points could lead to inaccuracies in the median formation.
Surface Continuity: Verify that the surfaces of the curbs are continuous and that there are no gaps or breaks in the geometry. Discontinuities might cause the software to fail in creating the median.
Target Point Validation: Double-check the elevation and coordinates of the target points. If the target curb's profile is inconsistent, the median top might not form as intended.
Software Settings: Review the corridor modelling settings. Sometimes, issues arise from incorrect targeting rules or parameter configurations within the software.
Check the Slope or Transition: If the median has a varying slope or transition at the problematic location, ensure the software is accounting for these variations properly. Adjust the template or apply overrides if necessary.                                  CashNetUSA loans
Manual Adjustment: If automatic targeting fails, consider manually adjusting the median top at the problematic location. This might involve editing the corridor cross-section for that specific station.
Rail Community
