Civil 3D Forum
Corridor Issue with RetainWallVertical Subassembly
4 REPLIES 4
matthew.andersonYXZ8M
285 Views, 4 Replies
Hi All,
I'm widening a road and need a retaining wall where I cut into the hillside (see plan view.png).  I am using OverlayWidenMatchSlope1 subassembly and a shoulder, which works great without any corridor error messages.  When I try to add the RetainWallVertical subassembly (see assembly.png), I keep getting error messages in my event viewer "Value on wrong side of alignment or profile..." (see attached event viewer.png).  The wall is "left" attached.  I wasn't able to find any solutions in the forums, so hoping someone can help.
Matt
4 REPLIES 4
Can you post a screenshot of Assembly Properties, Construction tab?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Hi Tim,
Thanks for taking a look at this.  See attached for assembly properties construction tab.
Your retaining wall subassembly is listed as in the right group, but the screenshot of the assembly has it on the left.
Tim Corey
Redding, CA
I guess I am missing something big here.  OverlayWidenMatchSlope1 does not have a "side" parameter (can't mirror it or assign to the left side), so I assigned it a negative insert point offset, which shows it on the left side of the assembly.  Any suggestions for that?
Matt
Rail Community
