Corridor Error
Corridor Error
Corridor Error
Hi Everyone,
My corridor does not seems correct in model view,
i have attached screenshots on the corridor and the assembly i am using,
kindly have a look and see if you can help.
Thanks & Regards,
Jatin
CivilFlow
Make sure your corridor has no bow ties or regions with gaps. Then go to the corridor surface\boundary option (under corridor properties) to add a “corridor shrink wrap boundary”. This should force the TIN triangulation to the corridor edges.
I hope this helps!
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Jeew-m
Dear Friend,
This video will be helpful to solve your issue. As Mike has explained you have not added a corridor surface boundary.
https://www.youtube.com/watch?v=JBBu8pGPA9U
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Thanks @Jeew-m @CivilFlow,
But is is the corridor itself not the corridor surface, the corridor has no bow ties i have checked for that and surprisingly the corridor surface is absolutely fine, i feel it is the code set creating the issue.
