corridor end grading
CADmgrMike
CADmgrMike
I'm curious how others deal with tieing the ends of corridors to existing or proposed grading.
In the attached screenshot, on both sides of the railroad is a proposed C&G with sidewalk.
How would you transition the proposed concrete work into the existing railroad concrete panels?
Stop the corridors xx' back and use feature lines to do the grading transition?
That's how I approach these issues presently, but I'm curious if there are better methods.
I end up with these small surfaces in my design transitioning any corridor ends to something else.
The method works, but when you start thinking about using code set styles to do your concrete or pavement hatching like what I have shown, now I also have these little pieces of hatch to add to the drawings also.
Give me your thoughts.
Thanks.
Mike Porter
https://provostandpritchard.com/
Replies (9)
Joe-Bouza
Its that or come up with a sub that matches existing
Joe Bouza
sboon
Assuming that the edges of the railway crossing panels are represented by featurelines then it should be possible to run the corridor all the way over the crossing, using targeting and some generic subassemblies to build the tapered ends of the sidewalk.
Post a sample drawing and I'll take a shot at it.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
CADmgrMike
I attached the drawing that I used for a screenshot.
In this particular instance, the corridor goes over the RR tracks and I just separated the region start and stop points.
My main reason for asking the question was to hear the approach others use when you have a corridor where the end of the corridor needs to match up to something that doesn't allow the use of the intersection wizard.
Another example might be where a simple crowned road corridor ends at the outside edge of a basin that was designed with feature lines and gradings.
Thanks for the response.
Mike Porter
redtransitconsultants
Yes, that's how I would approach it. Stop the corridor on either side a desired distance away. Then use feature lines and grading groups to generate another suface of the area in between. Then I create a Composite Surface of the corridor surface and any other surfaces by pasting them together in the order they need to appear. Only issue is if the feature lines are not dynamic to the corridor, these areas need to be updated - but the system works pretty well.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
sboon
Here is my solution.  I'm not sure of how you intended to transition the curb and gutter so I left that out.  I started by creating featurelines at the edges of the railway crossing slab then adding featurelines from that to the front and back edges of the sidewalk at the ends of your current corridor regions.
undefined
Next I created a new assembly using a generic LinkWidthAndSlope and a copy of your current sidewalk.  I added two new regions to your corridor.  For the low chainage side of the crossing the generic link is targeted H & V to the inside featureline (currently highlighted in red.)  The sidewalk sub is targeted to both the blue and yellow featurelines, also for H & V.
undefined
On the high chainage side the targets are a little different, the generic link is targeted to the farther of the two featurelines, and the width of sidewalk is only targeted to one FL.
Steve
Steve
kcobabe
I've had to do this on a park with a train.  I handled the crossing at grade as an intersection.  Considering most of the time the concrete is probably going to but up against the edge of the existing edge of railway anyway.  My aerials I did the same way without a bridge.
If you get a landscape architect involved they will almost certainly tell you they want you to curve it in to match.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
CADmgrMike
sboon,
Definitely going to check your drawing and method out a little more. Might be a way to at least keep the tranistion part of the corridor. Not sure how much it would help with code set styles and hatching. Have to study that one a little bit more.
Thanks for the help. You've at least given me something to compare my current method to.
Mike Porter
CADmgrMike
Steve,
You get kudos because you do it like me. Smiley Very Happy
Mike Porter
Thanks Mike! I will also have to take a look at Steve Boon's method. Always interested in new ways of doing things
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
