I have a corridor for a roadway project and at some point the entire proposed corridor dropped in elevation 3-4". I have a version of the drawing where in the section view there is a "section" line that shows the 3-4" low and the "corridor section" at the correct elevation, but if I rebuild my corridor it drops the 3-4". The corridor dropped by the same amount the entire length of the project.
The corridor was build an alignment for horizontal control and existing surface for vertical control (matching existing crown to proposed crown).
Before rebuilding the corridor:
After rebuilding the corridor:
I feel like there has to be any easy fix, but I don't work with corridors often enough to figure it out easily.
