Civil 3D Forum
Corridor conditional sub-assembly adjacent to offset target start/end issue
4 REPLIES 4
dnietubicz
628 Views, 4 Replies
I've created a corridor with conditional sub-assemblies. I have polylines for driveway targets along the mainline. If the assembly finds one of those it puts the appropriate driveway sub-assembly in its place. If it doesn't find any polyline targets, then it puts a shoulder & swale sub-assembly in place. Under "Edit Frequency" I have "Adjacent to offset target start/end" set to YES, but the automatically added sections 0.01' on either side of found target aren't functioning correctly. I end up with blank areas in-between the driveways or adjacent to them. If I manually add a section close to the driveway it does fill in the corridor with the appropriate shoulder/swale sub-assembly. Is there a setting to increase the adjacent distance from 0.01'? Doug
4 REPLIES 4
AlmasSuljevic
in reply to: dnietubicz
Hi dnietubicz,
The only available setting that controls corridor creation options are in teh CreateCorridor command settings. There you have option to turn on/off "adjacent to offset target" under "Assembly Insertion Defaults". Everything else is hard-coded.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Yonas89
in reply to: AlmasSuljevic
I have the same problem. I am using 2017 and it looks that this problem was not solved yet. I have 60 driveways which means i have to ADD 120 sections manually.
ytzvib
in reply to: Yonas89
Anybody had luck with this yet? I have the same problem.
Yonas89
in reply to: ytzvib
@ytzvib Unfortunately not. I've noticed that the problem occurs with custom subassemblies. If you use stock subassemblies everything works ok, but most of the time is not an option...
Rail Community
