Correctly export LandXML surface (without additional triangulation)
jamesmac1201
jamesmac1201
I need some advice on how to properly export a surface in LandXML format AND the surface maintains it's original shape. I've attached two files of the same surface. One is a GeoTiff surface and the other is a LandXML surface. The GeoTiff surface is how the surface should look. The LandXML surface, however, adds additional triangulation to the surface upon export. Not sure why it does this. Any suggestions would be appreciated.
Replies (22)
andrewpuller3811
It is not in the File menu in Civil 3d 2021, 2023 or 2025.
Generally, you can go to the output tab of the ribbon and you should see Export to LandXML on the export panel.
LandXML export can only export Tin Surfaces in Civil 3d, not Grid surfaces if you have made that one from your dem file.
You can either create a Tin Surface and add the DEM file, or create a Tin Surface and paste the Grid surface into it.
Either way, you can export the resultant Tin Surface.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
matt_anderson_pe
Civil 3D has two surface types - a TIN Surface, and a DEM Surface. (Not counting the Volume surfaces)
The DEM surface does not export to LandXML.  To convert a DEM to TIN - you need to create the TIN surface, and paste in the DEM.
As far as I can tell - Global Mapper can do the Export to LandXML directly.  <--  @dsmapping
Matthew Anderson, PE
neilyj666
How is this code run? All the paths etc look to be hard coded
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
