Correct grading, yet wrong triangulation
lemuel.catral
lemuel.catral
HELLO EVERYONE 🙂 I am having a very difficult time solving this one. As you can see the grade looks fine(see photo1), like the way it should be. But the time I triangulate it (see photo2) it is completely different. To give you a clear understanding of what it should look like, i have provided it below (see photo3). I hope i explained it well, and provided the necessary detail for my problem... looking forward to everyone's replies~.. have a great day ahead!!
Beka_Tchigladze
@lemuel.catral
Hello, you have to grade objects properly one surface is over the other you can change Feature Line style order to grade, it seems that your feature lines are on the same site and one feature line takes elevation from the second one, you have an options either to change feature line order to intersect in Z or try to solve it with paste surface last pasted surface wins.
You can also change site for you feature lines to force not to intersect with Z value.
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
neilyj666
Following on from the great advice given by @Beka_Tchigladze, I would be very wary of gradings intersecting in the same site as, based on my experience, they can be very flaky and crash or totally corrupt your drawing.
That said when gradings work they are great but more often than not they cause more problems than they solve and  it doesn't look like Autodesk are looking to fix them any time soon.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
lim.wendy
Hi @lemuel.catral,
Welcome to the Civil 3D forum. Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
