copy to clipboard failed error civil 2017
I have a tin surface that I created and now I need to add a proposed road into my finished surface, but when I try to paste my road surface into the finished ground surface that is already created I get a message saying "Error preforming edit", has anybody else had this problem and know how to fix it?  I am running civil 3d 2017 now but when this project was created we was using civil 3d 2014.  I've had quit a few things that I'm seeing different now.
I noticed that my corridor was targeting the existing surface so I changed it to target my finished ground.  Can I still add the corridor surface to my finished ground even though that is the target?
Civil3DReminders_com
Check your corridor for crossing corridor feature lines. I find that this is usually the cause of the error message.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Yoffre_Vargas
@Anonymous
no insurance intersection on your surfaces
upload your drawing and give you a help
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
AC3D 2016-2017
Windows 10
Intel(R) Core i7-6100 @ 4.0 GHZ
64 gb Ram + 64bit
500gb ssd + 1000gb hhd
Nvidia Quadro 4000
Yoffre_Vargas/Educator_Expert/ECUADOR
Si mi respuesta solucionó tu problema, por favor, márcala como Solución Aceptada y haz clic en Me gusta.
