Civil 3D Forum
Copy and Paste scale issue within same drawing
8 REPLIES 8
Message 1 of 9
jtrolan
488 Views, 8 Replies
When I copy and paste any object within this specific drawing, it pastes at a massive scale. Please see images attached for example.
I have tried the classic turn on and off, INSUNITS but nothing seems to work. If I work in autocad this issue is resolved however i need to use functions only available in civils. image.png
Tags (3)
Labels (1)
8 REPLIES 8
Message 2 of 9
jtrolan
in reply to: jtrolan
WORK ARROUND SOLUTION
- Purge All
- Copy and Paste Orginal into new drawing
- Save over file
(Work arround. Not a technical solution)
Message 3 of 9
tcorey
I wonder something. Check your Civil 3D drawing settings (_AECCEDITDRAWINGSETTINGS) On the Units and Zones tab, check the Drawing Units. This should be set to Feet.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 9
J-Porter
Also, why are you copying and pasting the same block into the same drawing?  Why don't you just use the COPY command?  You run the risk of unnamed blocks by copying and pasting.  That can cause all sorts of issues in the future.
Message 5 of 9
jroot
Check to see if the block itself is Annotative.  Depending on a number of settings, when you copy/paste a new one it could become a different size.
Message 6 of 9
jtrolan
in reply to: jroot
This is not a block. Its poly lines and a hatch selected and copied together. It occurs even when copying a single option.
Message 7 of 9
jtrolan
in reply to: J-Porter
It also occurs when using the copy command or cmd+c & cmd+v.
This is also not a block. Its numerous polylines and a hatch.
Message 8 of 9
LucasHicks
If you can post the drawing you'll more than likely get an answer quickly.
OpenRoads Designer, Civil 3D
Message 9 of 9
AllenJessup
If you can't post the info in the drawing. Make a copy and erase everything except the polylines and hatch you show in the image.
Allen Jessup
CAD Manager - Designer
Rail Community
