I have a drawing that was sent to me that has several lines of "text" that were used to label contouts....Is there a way to choose each individual string of text as a group and have each one convert to a mtext without stacking them together. I obviously want them each to stay at there current location.
Solved by wbrustle. Go to Solution.
I havent been able to check this discussion group until now, but it sounds like the problem was solved!!!! I am greatful that my question helped others and thank you for everyones inout. I will now try this lisp routine.....thanks again:)
This is perfect. Thanks - Just did it in Civil 3D 2024 version.
Prevents all text from conglomerating into one paragraph & maintains its original position.
