Converting Line, Polyline & Spline into a Profile in Civil 3D.
Message 1 of 10
I was digitizing a profile data from a DGN file into civil 3D. I was wondering if there is a faster way to convert directly the polyline profile into civil 3D profile. In the Pofile Layout Tools, there is Convert AutoCad Line and Spline but a message prompt that the "Selected entity cannot be converted." (Spline or Polyline) except for the line which is from the exploded polyline. The prompt also specifies "Select a line, quadratic spline to convert:" I am not sure and do not know how to create a quadratic spline. Only the one I know is just a spline.Capture.PNG
Replies (9)
Message 2 of 10
AllenJessup
A few links that might help:
Spline Command, SPLINETYPE, How to convert Splines to Polylines.
Can you post a drawing with one of the splines in it?
Allen Jessup
CAD Manager - Designer
Message 3 of 10
Dexterel
use NETLOAD to load the dll
use PFP to convert poly to porfile
Message 4 of 10
This is amazing. Thank you so much.
Message 5 of 10
@Dexterel
Hi
Please can explaine what you mean by PFP ?
Message 6 of 10
AdammReilly
@Anonymous
He attached a zip file, with a dll file in it. You would extract that dll to a folder, use the NETLOAD command to load the dll into Civil 3D then type PFP to run the command in that dll file.
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
LinkedIn | Twitter
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Message 7 of 10
@AdammReilly wrote:
@Anonymous
I did already but i received message # Unknown command "PFP". #
Attached my test file
I am using Civil 3d 2015 _64
Message 8 of 10
AdammReilly
Not sure why it didn't work for you. Did you use NETLOAD to load the dll into civil 3d?
It loaded fine for me, but I'm running 2019.2. Perhaps your version isn't supported by that app?
I ran it on the test file you provided and it worked, except the profile it generated was shifted to the right. I moved it to line it up with your polyline, just to verify it was correct.
Adam Reilly
Windows 10 Pro
LinkedIn | Twitter
Group Leader badge
LinkedIn | Discord
Message 9 of 10
henry_lozano
netload can be successfully loaded to any version oh civil 3d however when you executing the php command  Does not recognize.  It is compatible on civil 3d 2016-2020. PHP is the command to be used to export your polyline into your Profile.
hdl
Message 10 of 10
120230702016
Community Visitor
Community Visitor
yes it converted but it's still a polyline in terms of the properties
