convert feature line to alignment
Message 1 of 17
hello everybody
i know we can convert aligment to feature line , but can we convert feature line to alignment ???
any suggestion
thanks
Replies (16)
Message 2 of 17
Jeff_M
Out of the Box, no.
If you use third party tools, such as Sincpac-C3D, then yes. (CAPFEATURE - Create Alignment/Profile from Featureline)
Jeff_M, also a frequent Swamper
Message 3 of 17
wfberry
You Can:
Offset the Feature Line (say 1') Explode it. (Changes to a polyline).
Offset the Polyline back, define it as an alignment.
Bill
Message 4 of 17
nyloncrack
If it's a corridor feature line you want to convert...
Make Alignment
select corridor
corridor contextual tab - launch pad panel - alignments from corridor
cmd line> Select a corridor feature line: pick the feature line to convert
Create Alignment dialog box - Name the new alignment, uncheck Create Profile (make next with more flexibility).
New Alignment will be indicated in corridor.
Make Profile of Alignment
select corridor
corridor contextual tab - launch pad panel - profile from corridor
cmd line> select a corridor feature line: select same feature line (may want to freeze the layer the new alignment is on, making it easier to pick feature line, or use the draworder command and move the alignment back).
Create Profile - Draw New dialog box - Name the Profile  and set Profile Style/Label Set as desired.
New Profile should appear in the Profile of the base line alignment used in the corridor
Does that sound reasonable?
Message 5 of 17
Has this been changed in the 2.5 years since your last post Jeff? Can a figure be converted into an alignment?
Also, another suggestion was to offset the figure then explode it to convert it to a polyline. Then offset it back into place and make an alignment out of that. When I explode the figure, it converts to a 3D polyline, and I can't make an alignment from a 3D polyline, right?
Message 6 of 17
jmayo-EE
No but there is a command to convert the 3d pline to a 2d pline.
Convert3DPolys
Also noe that you may want to flatten the feature line of survey figure to a constant Z value prior to exploding. This will produce a 2d pline vs a 3d pline after the explode. It will also keep the arc segments.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
Message 7 of 17
Does not work on 3d poly or feature lines though, right?
Message 8 of 17
Yzne_
I believe to convert featureline to alignment we must have the elevation on the vertices too.
Message 9 of 17
ChrisRS
Alignments appear to 2D objects. You do not need vertex z information
Christopher Stevens
Message 10 of 17
rl_jackson
SMH!
Rick Jackson
Survey CAD Technician VI
Message 11 of 17
Yzne_
If we can have vertex z information to make a profile out of the featureline it would be easier than creating it all over again I guess.
Message 12 of 17
ChrisRS
The suggested process does leave the vertex z information untouched, so it remains available.
  1. Make a copy of the feature line at the same location. (use snaps.)
  2. Make sure that the copy is 'flat', that is all at the same elevation. FLATTEN does not work is arcs are present; arcs become tessellated.
    The only way I know of is to use the Constant Elevation option of Flatten Garde or Elevation button in the Elevation Editor. Much faster than manually editing each vertex elevation.
    ChrisRS_0-1649643426553.pngaa
  3. Explode this 'flat' feature line. You will now have a 2D polyline with any arcs intact.
  4. Click Create Alignment from Objects and select the 2D polyline.
  5. The original 3D feature line is still available.
    1. You can project the feature line to a profile view, based on this alignment.
      This is shown in red in the upper illustration.
    2. You can add the 3d feature line to a new surface. (Add to Surface As Break line.)
      Then create a surface profile as shown in the lower illustration.
Note: This just an illustration. Legibility is not the main point.
Good Luck!
Christopher Stevens
Message 13 of 17
Yzne_
Thanks a bunch for this explanation. I know this already and I do kinda same thing, but what I was asking for is that Autodesk creating a built-in tool to convert from Featureline to Alignment and to provide the profile to the alignment from the featureline Z vertices values. This would be a great help where you can find some doesn't like to deal with featurelines at all.
Message 14 of 17
ChrisRS
You might want to post this in the Civil 3D Ideas sub-forum. That is the place to suggest improvements. There seems to be more I am told that Ideas is monitored by the C3D team. It is just my opinion, but I think it more likely that issues without workarounds might generate more interest.
Suggestions:
  1. Post this in the Ideas forum.
  2. This is a pretty straight foreword process. There may be a LISP or Dynamo solution. I am not proficient in either. I suggest that you start a new post in the Civil 3D or Customization forum. I don't which is more appropriate.
    "I want to create an alignment based on an existing Feature Line, while keeping a copy of the feature line, with 3D intact. Manually I would make a copy of the feature line, flatten the copy. explode it and use it to make an alignment".
Christopher Stevens
Message 15 of 17
tonykB72MP
CTC Software has a free tool in their Project Manager Suite of tools (Feature 2 Align) that will convert feature lines, and/or survey figures to alignments using native C3D create settings. They also have many other time saving tools within the suite for a modest price point that will pay for itself. They offer a free 14 day trial to get to know the tools along with many support videos and a responsive support team if you need more help.
Message 16 of 17
tcorey
As was posted earlier, there are a number of third-party solutions to this problem. SincPac and Kobi Tools both do. DotSoft probably does, but I'm not sure. @TerryDotson  will know.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 17 of 17
TerryDotson
Thanks for the mention.  Yes, we convert a selection set of linear objects (including FeatureLines, 2D/3DPolys and more) to alignments in a single process.  At a glance it looks like one could acquire all three of the products @tcorey mentioned for the price of the previously mentioned package, and that 3x priced product is per seat per year.
