Conversion from Percent to Degrees
rolf.hoffmann
Message 1 of 8
rolf.hoffmann
My company mainly designs in Degrees of slope and not Percent of Slope, the way Civil 3D is designed.
It was brought to my attention that there is a flaw in our conversion to degrees in expression for labeling slopes and change in grade.
Eg. if you have a -5.0% slope going into a +5.0% slope that would be a grade change of 10.0%.
Now lets look at the same slopes but in degrees, Please note that the conversion from Percent to Degrees is (ATAN x (Percent/100)). -2.8624 deg(-5.0%) slope going into +2.8624 deg would have a grade change of 5.7248 deg.
The problem is that the conversion of 10.0% to Degrees is equal to 5.7106.
Can anyone shed some light on this conversion dilemma, and give some possible solutions.
Thanks Rolf Hoffmann
Replies (7)
Message 2 of 8
wfberry
Based on your formula what would you get in degrees for a 100% slope?
Bill
Message 3 of 8
rolf.hoffmann
Based on the formula, a 100% slope would be labeled as 45 deg.
Message 4 of 8
wfberry
atan (100/100)= .785398  for a 100%  slope
I just haven't figured your formula out.
Message 5 of 8
AllenJessup
I had thought it might be a rounding error. But I went out 12 decimal places and am still off by 0.02%. It may be that that's the limit of accuracy of those calculations.
Allen Jessup
CAD Manager - Designer
Message 6 of 8
rolf.hoffmann
Thanks Allen for your reply.
After wfberry replied, I did some thinking that this maybe to many unit conversions.  so I rethought the process.
instead of accepting Civil 3D's grade change expression, I thought I would create my own.
My original formula was "ATAN(gradechange), this is using the Civil 3D data from the expression editor.
Instead I wrote this, ((ATAN(GradeIn))-(ATAN(GradeOut)). what this does is solve two things. One, I stay in the same units till I use the expression in a label, and two, create my own grade change equation reflected in degrees.
So to review, the original GradeChange is in Percent, so a GC of -5.0% to +5.0% is 10.0%, which translates to 5.7106 deg.
My new Grade Change is GradeIn of -5.0% (2.8624 deg) - GradeOut of +5.05% (2.8624 deg) = 5.7248 deg. a Difference of 0.0142 deg which is only about 01 minutes difference, but this error increases with the increase of change in grade.
As a double check I did a larger Grade Change +5.0% to +100% = 95% or 43.5312 deg, compared to 2.8624 deg - +45.00 deg = 42.1376. a difference of 1.3936 deg, NOT GOOD!!
My New Grade Change shows me the true Grade Change in Deg with No errors, and I can display it in Decimal, or dms.
thanks for bumping my brain into overdrive.
Message 7 of 8
ChrisRS
Glad you resolved this.
The underlying  issue is that slope or grade a indications of rate of elevation change with distance, not angle measurements.
Christopher Stevens
Message 8 of 8
Joe-Bouza
Is my the display for degrees right in the composer? No conver needed
Joe Bouza
