Contour Labeling
Contour Labeling
Contour Labeling
Hi all,
I am trying to apply contour labeling to a surface that I have created. This surface was created using a point group. When I try to apply the contour label to the contour, I am given the prompt to select a contour, but when I click, nothing appears. Here is the command prompt:
Command: ADDCONTOURLABELINGSINGLE
Select a surface <or press enter key to select from list>:
Surface:  Clay Thickness
Select contour line:  <Osnap off>
Please tell me what could be the issue.
Thanks in advance,
Dustin
I discovered that the the default contour labeling layer was turn off. When I turned this layer on, the contour labels appeared as random black lines. Instead, I want my contour labels to be numbers.
Joe-Bouza
Good you discovered the layer. examine the contour label style in use to verify it has the component you seek on a layer that shows
Joe Bouza
Dexterel
The problem is that the label dose not intersect any contour line. See snap.png
Try to change snap to on and ensure the contour label line intersects a contour.
Also check tat you are displaying majors and minor contour labels See cons.png.
wfberry
Just drag the line until it intersects.  There is no snapping.
Bill
Dexterel
in the interest to be proactive please don't repeat what I already said.
