Civil 3D Forum
Connect Read/Write to Oracle Arcgis DB SDE or Filegeodatabase in Civil 3D 64Bit
1 REPLY 1
lucianoNYFNC
400 Views, 1 Reply
Hi, area there any way to connect with Oracle Arcgis Database SDE or Filegeodatabase in REAd/Write mode using FDO provider in Civil 3D?
In my test, I receive the follow error...
Or exist any error in my config connection?
  • civil3d_conn_postgis.png (Connection with postigs)
  • arcgis_conn_oracle.png (Connection with orace sde)
  • arcgis_conn_fgdb.png (Connection with filegeodatabase, in this case, do not error show, but don't connect)
Luciano
1 REPLY 1
rl_jackson
in reply to: lucianoNYFNC
In some cases, Map3D will have issues with FDO connections. I have found that by closing the program, and going to the properties of the shortcut and make the program "Run as Administrator" that it resolves this issue. Not going to say that its your current problem, but worth a shot.
Rick Jackson
Survey CAD Technician VI
Rail Community
