ConditionalCutOrFill no applying subassemblies
fteixeiraR39AC
fteixeiraR39AC
I reading the help section of the ConditionalCutOrFill subassembly and it states that: "This subassembly automatically applies various subassemblies, such as generic links, widening, ditching, or daylighting subassemblies, to an assembly based on whether a cut or fill condition exists."
Civil3D is not applying the stated various subassembies, only the conditional cut or fill...
What is the issue?
Matheus-Lima
Hi @fteixeiraR39AC, you need to add more subassemblies after the ConditionalCutOrFill. The conditional subassembly is used to check if it is a cut or fill section and it applies a first slope parameter.
For example, notice here one ConditionalCutOrFill with type parameter as CUT and another one with the type parameter as FILL, plus subassemblies after the conditional ones. So, below I have 4 subassemblies only for daylighting.
For example, from the help article:
  • The top left side ConditionalCutOrFill subassembly is configured to automatically add a Bench subassembly when Autodesk Civil 3D detects that the assembly is in a cut condition.
On the top left, ConditionalCutOrFill Subassembly (with type parameter as CUT) + Bench Subassembly = 2 subassemblies (and you can add more).
Hope it helps!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Jeew-m
You can get more idea about the conditional cut and fill assembly from here.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
fteixeiraR39AC
Thank you for your reply!
