conditional cut-fill subassembly only partially works
Message 1 of 12
I have a fairly simple rehab assembly with cut-fill conditions - on the fill side, I have a slope to surface link, then a 5m bench at -2%, the a slope to width link and finally a slope to surface at 3:1 - this works - on the cut side, from the bottom of granular I have a slope to width link from which I have a a slope to surface at 3:1 - within the same assembly, this does not work - the targets are set - any help will be much appreciated
Barry
Replies (11)
Message 2 of 12
KMercier_C3D
What are the parameters you have for your LinkSlopeToSurface subassembly for the cut  which is not currently working?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 12
KMercer - thanks for addressing my problem - attached is a pdf showing the
parameters for both the link with and slope and the link slope to surface -
for some time, I wasn't setting the targets but after doing so only half of
the assembly was working - also in the pdf is a shot of the targets - your
*Regards,*
*Barry Sherwood*
*Peregrine Solutions*
Message 4 of 12
KMercier_C3D
Nothing was attached?
Pronouns: She/Her
Message 5 of 12
KMercer - my said there was an attachment but not through the forum I guess - here is the attachment
Message 6 of 12
kMercer requested additional info which was sent - no response since
Message 7 of 12
Dexterel
add the dwg and revcloud the area where the cut condition don't work. This should be solvable.
Message 8 of 12
KMercier_C3D
Thought I replied, not sure why it never showed up. I was able to recreate your assembly and it worked as expected. As posted by the other responder, you will need to post a dwg to determine the issue unless someone else is seeing something that I am missing.
Pronouns: She/Her
Message 9 of 12
thankyou -could you re-post please
Message 10 of 12
thanks for your attention to my problem - here is a copy of my dwg - all cut locations don't work - all fill locations work - some areas not enough surface - std fill ditch - will adjust
Message 11 of 12
KMercier_C3D
Sharing the file definitely helped.
If you right click on your assembly and look at the assembly properties you will see that the Cut condition was actually nested inside of the fill condition which is why the cut condition was never being seen by the assembly in cut (since it wasn't seeing fill).
To fix this right click the three assembly components in the cut side (the cut conditional and the two links) and select "Move To" then click the connection circle where the cut is connected currently. If you go back to Assembly Properties it should now look like this:
You may have to reset targets but it should be good to go after that.
Pronouns: She/Her
Message 12 of 12
KMercer - thankyou - that was exactly my problem which is now corrected - great problem identification and solution
