Compute Materials doesn't show Object
Hi!
I have a problem with the Compute Materials. I created a Assembly with some shapes and I need quantify it, but when I use the Compute Materials to do Takeoff, the objects doesn't appears in the box, like the image.
Does anyone know what I can do?
Thanks!
tcorey
Have you created the Corridor yet and is it sampled by the Sample Lines?
Post your drawing and someone will take a look.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Yes, I do.
Anyway, there is the file. Has some names in Portuguese, but the major names are English.
Thank you very much!
tcorey
Your sample line group is not sampling the corridor, only the surface.
Pick a sample line on the drawing. On the Ribbon, pick Sample More Sources. Add the corridor.
Tim Corey
Redding, CA
Thank you!
I'm doing wrong. I has 2 sample lines group, I sampled with one but not another.
So, I did it. Thank you very much!
