Compound curve connected alignement
Matija55PGR
Matija55PGR
Hello Everyone,
Is it possible to create a connected alignment which contains compound curve?
Thank you for your help.
Jeew-m
In Civil 3D 2022 you can use 3 centered arc option.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
urosNR3GM
Observer
Observer
Thank you for your quick reply.
This was helpful.
Good Day, do you have a work around for instead of three-center curve,  I need to make with two curves only.
I always create alignments from polylines. I have complete control over the entity during creation. I can create. On the Home ribbon tab, Draw panel, there are several tools for drawing lines and curves, including compound and reverse curves. When I get the curves how I want them I join them using PEDIT, then turn the resulting polyline into an alignment.
Udo_Huebner
@Anonymous  schrieb:
... do you have a work around for instead of three-center curve,  I need to make with two curves only.
Use  three-center curve and use the same radius for R1 and R2 twice.
Gruß Udo Hübner (CAD-Huebner)
thanks! I was able to use this workaround.
