Civil 3D Forum
Complex slice - one 2d shape over 3d solid
7 REPLIES 7
Message 1 of 8
helloworld727
340 Views, 7 Replies
Good morning,
Is it possible to slice one solid with a complex 2D plane? I understand 'circle, ellipse, arc, 2D-spline, or 2D-polyline' are possible. However, I want to project a more complex shape (contained in one plane) onto a solid. File attached.
Is there a command for this, or is a series of 2D cuts going to be the easiest?
Cheers
7 REPLIES 7
Message 2 of 8
tcorey
in reply to: helloworld727
Slice command (be careful if you type, this triggers Civil 3D pressure pipe slice function) cuts through an object on a plane defined by 2d objects or user-selected points. Are you trying to slice a 3d object and apply a pattern as described by your polyline? I would extrude the custom pattern and then apply a slice to that.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
igi_pop
Like this?
Yee. However, your polyline can't be self-intersecting. You've got to break it down to non-intersecting parts.
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Message 4 of 8
Hey Iggy, what were your exact keystrokes to achieve that? I seem to cut the block in half : l
Cheers
Message 5 of 8
igi_pop
Cheers
I'm not exactly sure how you cut it, my red tranaparend solids are also two, as the number of surfaces used to slice.
Or is it the outer gray bit you need?
Iggy
Message 6 of 8
helloworld727
in reply to: igi_pop
I went slice -> **selected the cube** -> planar object -> **selected the polylines**
Message 7 of 8
igi_pop
Hey!
What you did was slice it in the plane where your polyline lies. Not vertical. That's why you likley cut it in half horizontaly.
Find the screencat attached, the proces is simple enough.
Cheers,
Iggy
Message 8 of 8
igi_pop
Don't know why the screencast is not active on the previous post.
I hope it's here now. Oh, there's an insert button! But it doesn't work..link below!
Rail Community
