Command line message
Automohan
Automohan
I really don't understood of this message when I open Autocad application it appears
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Alfred.NESWADBA
looks like there exists connections to Access-database files, either in the drawing (if the message appears only for some dwg-files, or for your AutoCAD configuration).
Does it appear only for some dwg-files? If yes please upload one of them so we can look into it (where the link is defined).
It's also necessary to know if you have plain AutoCAD or products which are able to have more types of connections to database files like Map3D or Civil3D.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Automohan
I am using Civil 3D 2017 as AutoCAD 2017 is maybe because of that.....
"Save Energy"
Alfred.NESWADBA
does that happen also with new drawings based on an original AutoCAD template (like ACAD.DWT or ACADISO.DWT)?
Do you see that message only when Civil 3D starts or every time you open a dwg-file or create a new drawing?
- alfred -
Alfred NESWADBA
Automohan
i will reply soon as possible...
"Save Energy"
Automohan
When I open AutoCAD message appears
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: APPMANAGER
Customization file loaded successfully. Customization Group: FEATUREDAPPS
Customization file loaded successfully. Customization Group: SKETCHUPIMPORTSKP
Customization file loaded successfully. Customization Group: BIM360
Customization file loaded successfully. Customization Group: ACPERFMON
Customization file loaded successfully. Customization Group: CHRONICLE
Customization file loaded successfully. Customization Group: GEOREFIMG
Customization file loaded successfully. Customization Group: CADSTUDIOGEOCODE
Customization file loaded successfully. Customization Group: AECARCHXOE
Customization file loaded successfully. Customization Group: MAPCLASSIC
Regenerating model.
Initializing....
There are no valid MS Jet providers installed......Done.
AutoCAD menu utilities loaded.Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Core...
*Cancel*
Command: *Cancel*
_RIBBON
*Cancel*
COMMANDLINE
Command:
Command:
Command: nil
Command: nil
When I open civil 3d message appears
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: PLANNINGANALYSIS
Loading AEC Base...
Loading AECC Base...
Loading Modeler DLLs.
Loading AEC Core...
Loading AECC QTO......
Loading AECC Land...
Loading AECC Subentity Selection...
Loading AECC Point Cloud...
Loading AECC ETransmit...
Loading AEC Application...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Project UI...
Loading AEC Utilities...
Loading AEC Layer Manager...
Initializing....
There are no valid MS Jet providers installed....Loading AEC Architectural Base...
Loading AEC Publish UI...
..Done.
Loading AECC Pipe Part...
Loading AECC Pipe Network...
Loading AECC Roadway...
Loading AECC Survey...
Loading AEC Schedule...
Loading AECC Plan Production...
Loading AecCivilBase...
Loading AECC Building Site...
Loading AECC Hydrology...
Loading AECC Pressure Pipes...
Regenerating model.
*Cancel*
Loading AECC Base Core...
Loading AECC Base UI...
Warning: Local command name not found for 'AeccDataSharing.AeccCreateMultipleShortcuts'
Warning: Local command name not found for 'AeccDataSharing.AeccAssocObjToShortcut'
Loading AECC Event Viewer...
Loading AECC Land UI...
Loading AECC QTO UI...
Loading AECC Pipe Network UI...
Loading AECC Pressure Pipes UI...
Loading AECC Roadway UI...
Loading AECC Survey UI...
Loading AECC PlanProdSvc...
Loading AECC Plan Production UI...
Loading AECC PublishSvc...
Loading AECC Publish UI...
Loading AECC AeccUiHydrology...
Loading AECC Mapcheck...
Loading AECC Mapcheck UI...
Loading AECC Building Site UI...
Loading AECC Point Cloud UI...
Loading AECC Management UI...
Loading AECC Text Component Editor UI...
Loading AECC Style Management...
Loading AECC Style Management UI...
Loading AECC Volumes Dashboard UI...
Loading AECC DataExchange UI...
Loading AECC ImxImpExpSvc...
Loading AeccUiAIWInterop110...
Loading AECC Model UI...
AutoCAD menu utilities loaded.*Cancel*
Command: *Cancel*
_RIBBON
*Cancel*
COMMANDLINE
properties
Command:
Command:
Command: nil
Command: nil
"Save Energy"
tmachado
Hi @Automohan, I get the same message. Windows 10 doesn't come with Jet Direct drivers installed, and as a matter of fact, they're not available since Windows 7 came out. The error message is safe to ignore.
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
