Command Line Auto-Hide?
Pointdump
Pointdump
Can you set the Command Line to Auto-Hide? I know I can set the transparency down to 10%, but Auto-Hide would be better.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Replies (17)
Jay_B
In 2013 and 2014, if you set the Command Line to floating or undocked, right click on the left grey bar of Command window>Autohide.
Not sure if this works for earlier releases.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Jay_B
Another way of doing this is to close command line by clicking the X on upper Rt. Corner and using Ctrl 9 to open it each time.
C3D 2018.1
C3D 2016 SP4
Pointdump
Jay,
Thanks. I've been using Ctrl + 9, but I miss things when the command line is off. I would like only the text lines to auto-hide, and it used to do that after a delay of several seconds. Nothing happens when I right-click the grey bar. I can only click the "X" or the Wrench.
Dave
Dave Stoll
Las Vegas, Nevada
Jay_B
Dave, sorry about that, I'm seeing the same here in 2014 maybe it can't be done.
C3D 2018.1
C3D 2016 SP4
Pointdump
Thanks, Jay. I'm glad to know it's not just me.
Dave
Dave Stoll
Las Vegas, Nevada
neilyj666
Try changing lines of prompt history to 1?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Pointdump
Neilyj,
Tried that. It doesn't seem to change anything. The number of text lines remains the same.
Dave
Dave Stoll
Las Vegas, Nevada
neilyj666
Did you try setting to 0?
Pointdump
Neilyj,
Yep. I tried numbers from zero to 20, and I'll be darned if I can figure out what that setting changes.
Dave
Dave Stoll
Las Vegas, Nevada
neilyj666
My last shot - try increasing the width of the command promt window so the text fits on one line (in the screenshot the promptlines is 0)
neilyj666
and then back to 3
Pointdump
Neilyj,
Well, thanks for trying, but I went back and forth between zero and 3, and nothing changed.
I'm going to dig up 2012 and see if the auto-hide worked on that version.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
2012 lets you Auto-Hide the Command Line.
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave,
You can't Auto-hide in 2014 but you can change the transparency to clear except when you roll-over it then it turns solid.
Pointdump
JD,
Thank you. I'm using 2016, and I do as you say, keeping it almost completely transparent unless I roll over it with my cursor.
Dave
Dave Stoll
Las Vegas, Nevada
aeshleman
I know this is an old thread but I ended up clicking on the dots just above the X on the command line and dragging it down until just the command line was showing, then the clipromptlines variable worked.
 To only show command history translucently and temporarily and according to your input history lines setting, you need to reduce the vertical size of the command line to its minimum (so only the command input line, the one in white, is showing).
I would still like the autohide feature on new releases but, oh well.
