Combining Ditch Corridors
sabrina.parkmond
Message 1 of 9
sabrina.parkmond
Hello, I want to merge my two ditches(create a continuous flow). There are two corridors and two alignments. Can anyone direct me on how to do this?
Replies (8)
Message 2 of 9
fcernst
Two choices: Intersection Wizard or Connected Alignment workflows.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 3 of 9
sabrina.parkmond
Thank you for the response, I am a beginner at Civil 3D, can you explain how I would use these options for a ditch? The only tutorials I can find are for road intersections.
Thank you
Message 4 of 9
fcernst
Right, but the Wizard is not just for Roads...
For channels, you would use a different Assembly set you create consisting of channel type components (i.e, not curb return subassemblies or roadway subassemblies).
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 5 of 9
fcernst
I am a beginner at Civil 3D..
Here's a quick example I worked up of a v-ditch with 4:1 side slopes intersecting with a v-ditch with 3:1 side slopes.
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 6 of 9
sabrina.parkmond
Would someone be willing to tell me in detail how to use the intersection wizard for ditches?
Message 7 of 9
sabrina.parkmond
Please see image on original post.
Message 8 of 9
CoraForun
Would have been nice to give a complete answer
Message 9 of 9
tcorey
Please consider that many respondents on the forum are busy professionals. You're getting free professional advice.
Here's an older post from my blog. It's from 2020 and needs further updating as targeting dialogs have changed significantly, but you should be able to use it to understand the manual process of creating intersections. As @fcernst said, you will need a different assembly for ditches.
Tim's Civil 3D blog: Corridor Intersection Primer -- Manually Create an Intersection
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
