Message 1 of 10
For some reason I cannot see my manual point I create using the cogo point creation tools.
Check to see what Point # it is set to use when you create the points. If the point # is already in the drawing it will go through the motions of create a point but nothing will happen just as you describe.
Rick Jackson
Survey CAD Technician VI
So I checked the point number and it does not seem to do anything. Also there's a minus sign in my cross-hairs in the lower right quadrant that I cannot seem to get rid of.
First can you post a file, and what versions....
The minus sign is a minor bug that will occur with any of the creation tools... This includes parcels, alignments, points etc..... The only way to remove it is to shut down C3D and restart it.
Rick Jackson
Do you remember the Point Number you gave to your point? If you do, you can try this:
Chicagolooper
I figured it out. It was something with my point styles and visibility not being on.
Use the Properties in your Point group and turn on visibility for your point style and labels.
Bill
