COGO Points Won't Convert
C3D 2018 sp 2 Win7
I tried EXPORTTOAUTOCAD and the cogo points do not convert to blocks. I tried (from Home tab) Points>Create blocks from COGO Points and it can't find any cogo points (if I select them they show up in the properties dialog as Cogo Points).
I've purged/audited/recovered but it still doesn't work.
anyone have an idea of what's going on?
Replies (22)
see attached dwg. it has several cogo points in it. but in the toolspace prospector tab no points show up. C3D does not see them, so apparently can't convert them, no matter what method I use.
I suppose I could explode everything but I'd rather know why I can't get C3D tools to do it.
Edit - I *can't* explode. I get a message Unable to Explode COGO Points for each cogo point in the dwg. And I sure thought i audited before, but now audit (and recover) report errors - one for each cogo point, and the cogo points are erased.
How the heck can I get to the cogo points so I can use them as we need?
Pointdump
David,
I don't see any COGO Points in your drawing:
Dave S
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Jeew-m
Dear Friend,
It seems like these are not COGO points. It says they are survey points. They may be related to a survey data base or some survey equipment. It may have been disconnected.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
It's odd - when I pick one and list it i get this:
Command: li
LIST
Select objects: 1 found
Select objects:
                  AECC_COGO_POINT  Layer: "E_LAND_Vegetation"
                            Space: Model space
                   Handle = 6b3
      Point Number : 1402
          Northing : 482825.3510'
           Easting : 772768.2220'
   Point Elevation : 1122.708'
   Raw Description : DTRE /10IN
  Full Description : DTRE /10IN
Description Format : $*
             Style : E LAND Deciduous Tree
 Point Label Style : <default>
      Survey Point : True
I am not sure what a "survey point" is. It's probably a direction to research in.
odoshi
Look a the last line of the LSIT command:
Survey Point : True
So, they came from a Survey Database, and are typically locked in the drawing.
Make a new Survey Database, and Add Points from drawing to the database.
Then right click Points folder in the database and Unlock in Drawing...
Then try exporttoautocad.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
Thanks. That should have worked, but didn't. When I tried to Import points from drawing and selected All the command seemed to end prematurely. No points show up in the point listing, locked or unlocked, Toolspace Prospector tab. I'm not sure why. AT least I learned something about survey points.
I tried selecting points manually and it's not seeing them. Corrupted dwg? I have moved past this, I was able to get blocks from a point file. thanks for the input.
Pointdump
David,
I tried every way I could think of to beat those points into submission. I even tried to Data Extract the points. No go. When you hover your cursor over one of those points you can see lots of useful information, but you just can't get to it.
Dave S
Dave Stoll
Las Vegas, Nevada
Pointdump
David,
This is killing me. I just tried using <<<_ATTEXT>>> with no luck. All this useful information that is beyond reach:ATTEXT.png
Dave
Dave Stoll
Las Vegas, Nevada
I know. We got this from a consultant. I got another drawing that had blocks in it instead of whatever those points are. It's a mystery to me.
Jeew-m
This video will show how to to make cogo points from those survey figures.
Jeewana Meegahage
Design Engineer
Pointdump
Jeewana,
You rock! That works. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Ji Jeew,
I have similar issue, when I see the list this is what I see,
Command:
Command:
Command: _AeccExportPoints
Command:
Command: LI
LIST 1 found
BLOCK REFERENCE Layer: "C-TOPO-PNTS"
Space: Model space
Color: 3 (green) Linetype: "Continuous"
LineWeight: Default
Handle = 116e
Block Name: "_DotSmall"
at point, X=-25091.712 Y=-6740.189 Z= 49.552
X scale factor: 6.160
Y scale factor: 6.160
rotation angle: 0d0'0.00"
Z scale factor: 6.160
Scale uniformly: No
Allow exploding: Yes
Can you please help. I wanted to export those points.
Pointdump
Saieesh,
Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
jroot
Sorry to dig this up from years ago but I'm having the same problem with the cogo points in a DWG from someone else. The attached .avi will not play in any of my Windows apps - do you remember what the solution was @Jeew-m or @Pointdump ?
Thanks!
Pointdump
Hi Joe,
I too couldn't open Jeewana's AVI file to refresh my memory, and I don't remember how he did it.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Joe,
Windows Media Player opens the AVI file. Jeewana converted all the points to Blocks and then used BURST Command to convert them to COGO Points.
Dave
Dave Stoll
Las Vegas, Nevada
jroot
Thanks Dave. Was there one more step after BURST? I don't think the BURST command creates cogo points.
Pointdump
Joe,
I tried it just now with the Old_Sauk_Sheets.DWG that @Anonymous posted in Message 2.
QSELECT >> COGO Points
Isolate Selected Objects
BLOCK >> Select Objects
BURST
Works good. Can you post your drawing? I'll test it out.
Dave
Dave Stoll
Las Vegas, Nevada
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
