Civil 3D Forum
COGO Points with Alignment Data
11 REPLIES 11
Message 1 of 12
3294 Views, 11 Replies
I've searched the forums, but didn't quite find what I'm looking for.  Let me explain my goal as that may be faster.
I have a series of data on an alignment which requires the station, offsets, and the northing and eastings.  However, I need to make a chart that gives this information as well. The information is field collected, and most of the information is included in the point data, save the station and offset.
What I need is a way to generate all the data together in one table, and a label that shows the point number, station, offset, northing and easting.  So far, we've been able to make a point table or label, and fill in the rest of the information (point table adding station, labels adding point numbers), but this has been very tedious and we're trying to find a better way to do this.  Any tips would be helpful!
(I am not opposed to using scripts, though I don't have the knowledge to write one myself.)
Labels (4)
11 REPLIES 11
Message 2 of 12
Jeew-m
Create two reports from the following.
Station offset point report
Create COGO Point Report
Then join the point data using point number in an excel sheet.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 3 of 12
tcorey
Do you know about User Defined Properties for Points (UDP)? You can create additional database columns for Station and Offset. Use LISP to generate the values for the Points and add them to the UDP, then a Point Label style that uses those properties from the Points. Once you have the UDP data populated, it acts like any other  point property and can be added to the Label Styles.
Reply to this message with your dwg file attached. The file should include the Points and the Alignment. I can make a UDP for Station/Offset, and then write a LISP routine that calculates those values and inputs them into the UDP. It won't happen today, as I have a training class starting in fifteen minutes and that will take all day.
If you don't want to attach your data to this public forum, you can send to me directly: tcorey at shasta dot com.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 12
Joe-Bouza
If you convert the Congo points to pipe network structures you can get all the data in one dynamic table; provided you continue to manage the structures in leu if cogo point.
export cogo to sdf
MAPIMPORT the sdf
MAPEXPORT sho create the object data as wished.
import GIS and map to structure parts
create structure style and label that looks like cogo point
make table
Joe Bouza
Message 5 of 12
Jeff_M
You may be interested in the Dynamic Point Linking available in the Sincpac-C3D add-on package.
Jeff_M, also a frequent Swamper
Message 6 of 12
stacy.tyler
Have you tried the new Project Explorer tool?  If you have an AEC Collection License (2020 or 2021) you could create a Table or external report by using it.  You can report the station / offset and offset distance of the point in relation to the Alignment when you use the Compare option in the Points Tab. All the Cogo Point information can be listed in the table too.
Message 7 of 12
tgaff
in reply to: stacy.tyler
Thank You Stacy, THAT's the way to do it! Move her number up a digit please.
Message 8 of 12
thuancao4124
in reply to: tcorey
I am interest on the Lisp code and learn about it : I want to define 3 UDP properties for a cogo point
station, station offset and side ( left or right of the alignment) and calling a Lisp function to
input alignment , and cogo point group to add UDP data into that point group.
Thanks.
Message 9 of 12
tanveerbhatti447
Yes i am also interested.
Message 10 of 12
Corey.HayesYYPD5
in reply to: tcorey
Thanks for this suggestion! Any chance you have a lisp routine established? Or is there a link to one you have identified?
Message 11 of 12
Corey.HayesYYPD5
in reply to: tcorey
Message 12 of 12
tcorey
in reply to: Corey.HayesYYPD5
Three years later, my employment status has changed. I am no longer independent and able to spend time writing free lisp. You should have gotten back to me in 2021 when I had the time.
Tim Corey
Redding, CA
Rail Community
