Code set value problem
florianshabani12
florianshabani12
Hi, in this pictures are shown cross sections from a reference corridor, so the original is created in another file and using data shortcut is inserted in this drawing, It is showing an error that this value in this code set label is interpolated, confirm the value in the corridor source drawing.
Any way it is not showing while printing, if anyone has the answer for this please take your time to answer
tcorey
Can you post the drawing files?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
cwr001
I think that's a normal message, I get it everytime I work with labels for datareferenced corridors and I've just been ignoring it.
(My guess is that it's just Autodesks polite way of saying "Please don't rely on us to expect valid, reliant results - check for yourself!" :-))
I didn't have any problems though - those warnings also don't print.
m_kasza
You can remove all yellow warnings.
Options/AEC Editor/Solution Tips tab and uncheck "Drawing"
ecfernandez
Hi guys! I agree with @m_kasza. In that way, the warning symbol can be removed from section views of data-referenced corridors. Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
saleh_rb2311
Community Visitor
Community Visitor
thanks for the help friend.
Warm greetings from Indonesia
civil BIM modeller drafter
