code points in cross section sub assembly is not shown in layout or it is too small
nazmirsh
nazmirsh
Hi after creating roundabout corridor , and creating cross section, in model i can see offset elevation code points with scale of 1:100 , but in layout with the same annotation scale with the model , the code points , are maybe 1000 times smaller ! so that u can not see any text in the view port for cross sections . i appreciate your help
@ecfernandez
ecfernandez
Hi @nazmirsh, you need to adjust the Code Set Style. Go to the Code Set Style and adjust the Label Style of that point code. Update the text height to at least 2.5mm. If the labels still do not have the desired height, play around with the values until you have the desired appearance.
 I hope this helps. Best regards,
Camilo Fernández
P.Eng | Transportation
LinkedIn
nazmirsh
thank you so much
ecfernandez
hey @nazmirsh, happy to help. Regards
Camilo Fernández
LinkedIn
